Extrude-Remove-Offset from Surface to retain wall thickness?
christopher_owens
Member Posts: 235 ✭✭
Maybe this will come in handy and maybe there are various ways to achieve this. I want to Extrude-Remove a feature that stays a value (eg wall thickness) away from a surface. That way if the height of the part changes I don't have to modify the "cuts". Plus the surface matches the "curve"/"angle" of the offset from surface. Similar to Shell but not removing all the face. I tired Move Face, creating an offset surface from the bottom surface to use "Up To Next" (Offset Surface?)
See that the Up to Surface goes all the way through the part. I would like a "wall thickness" at the bottom that stays even if the height of the part (where the sketch plane is located) changes or the angle of the Moved surface is modified.
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 669
I would do it as a blind then change the terminating face using a replace face with an offset.
1. Start with a small blind remove extrude to get the start of the faces you want to remove.
2. Start a replace face command. We are going to replace the terminating face of the remove with the surface we want to offset from.
3. Select the terminating face as the face to replace. Select the surface we want to offset from to be the surface to replace with. Since the normals of the faces are pointing opposite, we need to choose 'Flip alignment'. From here, enter the offset that you wish.
4. Go back to your driving sketch, edit it and if done correctly should update with the offset correctly.
Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com6 -
andrew_troup
Member, Mentor Posts: 1,585 ✭✭✭✭✭
I agree: the "Offset" option is pretty well concealed, and at minimum I think there should be a tooltip ("Offset Distance") which hovers BEFORE you click to enter a figure.
At present, it only tells you what you need to know once you have decided to use it.
It was attention to nuances of this nature which the early Apple Mac team realised was crucial to what became known as an "intuitive" interface.5
http://recordit.co/NW264lS5EO
"Onshape; doing more with less"
For those unfamiliar with "face normals": they are vectors, perpendicular to the face in question, whose "sign" is arranged to they always point towards open space, away from the solid.
