Embossed lettering on a vertical wall for 3D printing--chamfers and fillets don't work
Per your online manual wraparound lettering works only on cylindrical surfaces. In my case with a conic surface, I create one or more auxiliary planes close to the conic surface, create the text on it and Extrude/Remove Solid to a desired depth (the same would work with Create or Add Solid.) The problem is that I cannot have overhanging surfaces of the letters at an angle greater than 45 degrees from vertical. I've tried all kinds of fillets and chamfers, but they are very sensitive to geometry and never reach to the original conic surface at an angle <45 degrees.
Is there a way to emboss such text with a triangular or trapezoidal cross-section starting at the object surface? My particular part is at https://cad.onshape.com/documents/4c4858359bf08ffc25adaa50/w/49418311816425087e3893c4/e/4f5e366d7f43b3a9e6fb26ff
Thanks,
--Tony
Thanks,
--Tony
However, in my particular situation the text cannot be drawn directly on the conic surface, so I have to draw it at auxiliary planes at best tangent to the actual conic surface, and the largest draft angle I could use at an (uneven) 0.5 mm embossing depth is still too small (<30 deg) to avoid the use of supports...
In summary, it seems to me that this general problem will continue so long as the wrapping of the text is limited to only flat and cylindrical surfaces...
https://cad.onshape.com/documents/cfec40e2b66bb4ddb2f3414b/w/24132f252a02825eb0606641/e/c8e6602fb08acac97a10a38e
Now a really newb question: how do I install that Curved Text FeatureScript in my free account to use in my other documents? .I've tried searching for FeatureScript, but could not find this simplest of answers...
