Pattern & Sweep (New Custom Feature!)
MichaelPascoe
Member Posts: 2,686 PRO
Pattern & Sweep
How to add a custom feature to your toolbar:
5
This one will save tons of time for those who do panels and walls. The example room took me about an hour with these tools due to my indecision. Without these tools it probably would have taken 6 hours give or take some.
There is a configuration button to show that folder, you shouldn't have to unsuppress anything manually.
The profile origin mate can be selected from an existing mate, or created on the spot. To create it on the spot, press the mate button over to the right. You can manually adjust the orientation of the mate by pressing the tiny mate icon in the input box, or you can click the quick orientation buttons I placed below the Profile origin mate box. The quick adjuster buttons are very helpful for this feature.
Could you use opExtractSurface[1] instead of fill, when getting the faces for transforming?
That means that faces with inner loops will work.
[1]: Onshape
UPDATE!
Note, when using profiles from a different studio:
Update!
opExtractWires(context, id + "opExtractWires", { "edges" : inputCurves }); var compositeCurves = qCreatedBy(id + "opExtractWires", EntityType.BODY); forEachEntity(context, id + "makeWires", compositeCurves, function(curve is Query, id is Id) { var curves = dissolveWires(curve); var path = constructPath(context, curves); var start = evPathTangentLines(context, path, [0]).tangentLines[0]; var startOrigin = start.origin; var startNormal = start.direction; var startPlane = plane(startOrigin, startNormal); var sketch = newSketchOnPlane(context, id + "sketch", { "sketchPlane" : startPlane }); skCircle(sketch, "circle", { "center" : vector(0, 0) * inch, "radius" : definition.diameter / 2 }); skSolve(sketch); var profile = qEntityFilter(qCreatedBy(id + "sketch"), EntityType.FACE); // sweep the wire body opSweep(context, id + "sweep", { "profiles" : profile, "path" : qUnion(path.edges) }); var wireBody = qCreatedBy(id + "sweep", EntityType.BODY); }The Onsherpa | Reach peak Onshape productivity
Thanks for the input! Great idea, it would be a lot faster depending on the situation. I didn't choose the best example, but the reason I have the inputs in an array is so that you can do multiple complex sweeps. Lol, then I went and showed 4 straight simple lines... It would be good to have something like your code inside each sweep input in the array. This way if you want to sweep 4 straight lines, you only have to select the orientation once then click all 4 lines.
Is it possible to select the end mate connector to allow rotation along the path of the curve? Think roller coaster tracks where you want to have a bank angle, so you would start a 0-degree rotation normal to the curve's start, and end with whatever the mate connecter had set since you can rotate a mate connector along its primary axis fairly easily.
The Pattern & Sweep doesn't allow this functionality. However you can achieve this with the standard sweep feature by setting the Sweep Profile Control to Lock profile faces. Here is an example of how to do this:
https://cad.onshape.com/documents/38982e08a0853f0999682f95/w/f8057202b9bea051887ed79c/e/…
