Loft feature - keep cross section
jo_gr
Member Posts: 12 ✭
Hi,
Here is a link to a little project of mine. As you can see in the picture I would like to use the loft feature to make a solid connection between two circles (yellow part). How can I make sure that the cross section keeps the same and doesn´t shrink in the middle part?
Thank you in advance!
OptionsJohn_P_Desilets Onshape Employees, csevp Posts: 236@jo_gr Thanks! I see that you already used the path option in previous operations. Nice! I think you might have better luck using the sweep feature with 3D fit splines. I made a quick example off of your document. Let us know how you make out!
https://cad.onshape.com/documents/e000f13712bc34b9c47a4737/w/0cbc8d6d95b97a880e36d8ad/e/5f4bd6c473a0500b02c72886
1 -
OptionsEvan_Reese Member Posts: 2,066 PROThis one just seemed fun so I had to give it a go. I remembered a hose routing custom feature by @sebastian_glanzner that seemed perfect, especially since your document is called "water outlet". This way you don't have to create fit splines, or cross sections to sweep, and you get extra info about your hose specs. I also used my Freeform Spline feature to define the main path for all of the hoses, so you can edit like this which is kind of satisfying (the "Final" button is active"). Here's a link to my document
Evan Reese / Principal and Industrial Designer with Ovyl
Website: ovyl.io5
You can do this a few different ways. If you create a 3D spline between the start and end profiles you can use the "path" option in the loft feature. You can also use the sweep feature to ensure a constant cross section.
Website: ovyl.io
That is awesome, nice solution!
