I cant get the mass object in revolve tutorial
mari_stgomari_stgo Member Posts: 2
After completing the extrude tutorial I figured out I had a wrong dimension, then go to sketch fixed it and the simulator also fixed the revolve size. The thing is that when going to assign material, which I previously used with the wrong dimension, the material was already set, I managed to changed to other and the changed again to the one used in the tutorial, but when try to get the mass the window is completely empty. How to fix that? Thx u for ur support.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,996 PRO
    make sure you have the part selected when opening the mass properties window
