"external references are missing" without indications of which
 CaptainBisquick
                    OS Professional Posts: 33 ✭✭
CaptainBisquick
                    I drew two sketches on the top plane. As far as I can tell, they are independent of one another. But when I switch their order history, I get the "Some external references are missing" error, and I can't see why.
Sometimes I like to have more than one sketch in the same area so that I can avoid having my sketches get too crowded, while still being able to see the lines of one sketch while working in the other. The problem I have is when I begin editing the first sketch, I can't see the lines of the second sketch. That's why I switched their order history, but then received the inexplicable error.
             stevehess
                            Moderator, Onshape Employees, Developers Posts: 98 stevehess
                            Moderator, Onshape Employees, Developers Posts: 98 Hi @robert_christian , Open the Share dialog by clicking the blue button at the top right of the menu toolbar. Then, the "Share with Onshape support" right at the bottom of the Share dialog. If you filed a ticket someone will reply with a more detailed reply asking you to share with them. Hi @robert_christian , Open the Share dialog by clicking the blue button at the top right of the menu toolbar. Then, the "Share with Onshape support" right at the bottom of the Share dialog. If you filed a ticket someone will reply with a more detailed reply asking you to share with them. Steve Hess \ Onshape Inc.5 Steve Hess \ Onshape Inc.5
If you turn on "show constraints" in the sketch which was created second, but which is now first: you will probably see one or more of them in red: these are constraints which will have been inadvertently created (by unperceived snapping when you created the sketch)
The switching of order is actually a good diagnostic technique to identify such unwanted constraints.
If you select these constraints by clicking on them with the mouse, you can "Delete" from the keyboard or RMB.
If there are no constraints in red, you have a rogue situation and should submit the model to Support for checking.
Please check whether you selected top plane or sketch face to create second sketch....
I sent a support request to Onshape support.
Perhaps you should file a support ticket & share your doc with Support. They can get to the bottom of it.
@stevehess, ya, I did. I don't know where the 'share with OS support' feature is though.
@Paul_Chastell
