Whenever I export files (.obj or .stl) they are really small (not file size, size of the object)
gus_barth
Member Posts: 7 EDU
I've been having a problem recently where my exported files appear really tiny when imported into Prusaslicer, when I import them into Cura they automatically scale themselves up. For now, Cura is fine but I prefer Prusaslicer so I was hoping someone here would have the answer
gus_barth
Member Posts: 7 EDU
I figured it out, I've been exporting in meters instead of mm, switching to mm seemed to fix my problem0
https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first#latest
Here is one of the models, this one is in inches.
https://cad.onshape.com/documents/d75aeecbcda609f4cb4ad8fa/w/6a4dd95b715619b68ebebebe/e/b8f7d385517a27511a8dd881
This one is in mm.
https://forum.onshape.com/discussion/15688/add-units-to-obj-export
