Multi Mate Connector request
steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
edited February 2021 in FeatureScript
@konstantin_shiriazdanov
This is a great featurescript
A couple things that could make Multi Mate edits faster
  1. Display translate (offset) & revolve x,y,z delta coordinates for each item in the Transform array dialog
  2. Ability to reorder those items
    Hi, Steve
    I can't make transform parameters to display in multi row manner, if add all the parameters inside it looks like this:
    also the ability to reorder array items is already there by default
  • steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
    Thanks for the quick response
    I typically use Onshape on my iPhone, so I wasn't aware of those two items already being implemented.
    The way it works on the desktop is what I was looking for. So I’ll use my computer when I need to reorder
    Thanks for the info Konstantin
    And like I say - it is a great fieaturescript !!
    What you said above is an ACCEPTED ANSWER. And if I had the ability to click on some thing that says ACCEPTED ANSWER, I would. But evidently, I filed this under featurescript and it doesn’t appear to give me that option. I didn’t know that would happen
    No problem, I created a lot of threads on this forum, and get a very helpful answers, though almost every time I was forgetting to make it as a question.
  • Ulises_FMUlises_FM Member Posts: 74 PRO
    Hi Konstantin! First of all, I would like to thank you for your work on the MultiMate Connector FS, it is really helpful for creating robotic assemblies.
    I have a question, though. Would it be possible to get the opposite? I mean, to obtain the transformation information (such as dx, dy, dz, rotx, roty, rotz, or even the transformation matrix) from two already-created MC.
    I created a IR for that, but I believe your FS is really close to that already.
    https://forum.onshape.com/discussion/20536/get-and-set-pose-between-mates#latest
    I really appreciate your work. Thanks!
  • Konst_ShKonst_Sh Member Posts: 115 PRO
    you can make the feature which has query inputs for 2 mate connectors, evaluates their coordinate systems and evaluates transform from first coordinate system to another. this transform value you can print in console and copy to your external code, it will be a map with linear and rotational components.
    Thanks! I'll give it a try (even though I have never coded in FS)
    I see that you used to functions transform() and rotationAround() to apply the transformation. Do you have any idea if there is a function to get the opposite? Something like getTransform()?
    Cheers!
    When we saying transform in featurescript we mean the value of type Transform , to apply this value and make actual tranform of the body in part studio you need to use opTransform() function with certain arguments, one of which is the precalculated transform value. So here is the transform type and functions documentation:
    https://cad.onshape.com/FsDoc/library.html#module-transform.fs
    So the tranform() and rotationAround() will both return you Transform value, no need for additional getTransform().
    Ok, I get it. The way I imagine this kind of functinality is to be able to select two MC and get the Transform between them.
    I guess I need two MC as Query, the evMateConnector() function to get their respective CoorSystem and the functions toWorld() and fromWorld()
    Kind of Transform = fromWorld(evMateConnector(MC1)) * toWorld(evMateConnector(MC2))
    I'm aware that would not be the appropiate syntax but illustrates the idea.
    Any thoughts on how to print the Transform result in the user interface window?
    edited September 2023
    I suggest you to print transform value in featurescript notices console - it is opened by pressing { ! } button in top-right side of part studio page.
    Thanks a lot! It worked!
