Title block not an option when making a new sheet
Hi all,
I was wondering if there were some option I'm missing to include a title block into a new drawing sheet. I know I can choose a template, but I'm just getting started and would like to simply work with the defaults. The drawing template I get by default is "custom" though, and I can't seem to find it when I try to change the format of the new sheet. The help docs don't seem to have much to say about this.
Thanks so much.
  • Marco_AlbrechtMarco_Albrecht Member, Channel partner Posts: 1
    At the moment I have to select the template for every sheet separately. It will be helpful to have an option for using the template, I selected initially, at all sheets. Is that possible?
  • Jenny_JohnsonJenny_Johnson Member, Onshape Employees Posts: 11 image
    Are you choosing the Onshape templates when you make the drawing??
    Jenny E Johnson
    Principal Technical Services Engineer, Onshape
    jjohnson@ptc.com
