Mate connector defined based on a mate connector
monroe_weber_shirk
Member Posts: 103 EDU
in Drawings
I am using instantiator to bring multiple part studios into a parent level part studio. I want to connect the incoming parts in very specific ways and have mate connectors defined on all parts for making the connections. However, I want to be able to rotate and change the elevation of parts in the parent studio. I don't want to transform the parts themselves because they leave behind all of their sketches and mate connectors like lost souls when I move an imported part. This problem stems from the fact that when using mate connectors the ability to rotate and translate is lost.
- Is there a another method to bring parts into a part studio and get them into the correct position that I should be using? I know one answer is assemblies, but I can't use assemblies for other reasons.
- Could mate connectors be allowed to be defined based on a mate connector? This way I could import one part, add a translation mate connector to a mate connector that is on the part, and then bring in a second part that would mate to the intermediate translation mate connector.
