Exporting DWG as STEP or IGES
ajit_wadalkarajit_wadalkar Member Posts: 2
How do I export a DWG file as a STEP or IGES? If I right click on the tab on the bottom and select Export, I'm only given PDF, DWG, DWT and DXF as the options.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,876
    That’s right. While the IGES format (discontinued 26 years ago) supports 2D drawings, STEP does not so we only support these formats for 3D.
  • ajit_wadalkarajit_wadalkar Member Posts: 2
    The DWG file that I've imported into OnShape is actually a 3D drawing
    Really? We don’t support 3D DWG.
