How would I make a surface at the jionts of the fingers?
I have been using surface modeling and i am having troubles making a surface between the joints of the fingers.
Any suggestions?
Link to document : https://cad.onshape.com/documents/7dbea80e4c47ed2f0a0b9d00/w/12cb92ff8fe70359cb173582/e/3d47bc94b0f9d17f108d0b24
Any suggestions?
MichaelPascoe Member Posts: 2,447 PRO
Here is the approach I would take, see the diagram below:- Split the surface where the red dots are located
- Loft the lines that are highlighted in yellow
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
You can use a similar approach for each joint. Loft with lots of edge control will be the best tool here.Learn more about the Gospel of Christ ( Here )
You should be able to make a copy of this one @John_P_Desilets
