Multiple pivots in the Revolute command
jonathan_fether456
Member Posts: 5 ✭
I am having a problem getting an assembly to revolve using multiple levers. It is a toggle clamp drawing from McMaster Carr. I can get all the pivots to work, but cannot get the last one to work no matter which order I assemble it in. The geometry will work if all the levers can move freely.
Here is a link to the drawing if you are interested
https://cad.onshape.com/documents/02d64d40d29c4cb911b6cf69/w/6155985e2324d4cbff610561/e/01b6022859a75ba034b23974
