How to change the side that fillet tool acts?
marcos_pinto124marcos_pinto124 Member Posts: 11
I have been trying to make the fillet tool act according to the image (look on the right), but its not working. Instead of going up, its going down. What can I do?
Link for the document: https://cad.onshape.com/documents/a8ccc1f1f3ac1b70407a58df/w/f4440c3c1fd0277ed25bcb88/e/87be9b96a8b5203984a49c68
  • wayne_sauderwayne_sauder Member, csevp Posts: 625 PRO
    You cannot fillet between multiple bodies. You will need to boolean you parts together, or go back and change your extrudes to add, instead of new. The fillet should behave as expected then.
  • marcos_pinto124marcos_pinto124 Member Posts: 11
    Thank you for helping me it worked.
