Surface Area for Assembly
dave_fogliatti
Member Posts: 3 EDU
Is there a way to have the Mass Properties Tool show the outside only surface area for two mated parts in an assembly? I did a quick example with two unit cubes and wanted to have the Surface Area be calculated as 10 in^2 instead of 12 in^2 so the two mated (fasten tool) sides in the assembly did not count towards the surface area.
I'm a teacher and I'm doing the typical "assemble the cube" project but wanted them to practice surface area volume for each puzzle piece before the assembly. The volume is super easy but not sure how to do a bottom-up construction using mated cubes vs building each piece as one part.
Thanks,
Dave
Thanks,
Dave
