Improvements to Onshape - October 23, 2014
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015
The most recent build of Onshape was pushed this week with a number of improvements to visualization and performance. Here are some highlights:
Highlights:
- A new reference plane type has been added for curves and a point. This is great for setting up sweep profile planes.
- In Part Studios, suppressed and deleted selections in features show detailed feedback as of their status.
- New view modes including wireframe and Hidden lines removed are now in the view options under the view cube.
- Easily hide other elements of similar types (sketches, planes, parts etc..) in the context menu from either the graphics or List views.
- In a Part Studio you can select which Parts are exported to STL.
- Performance improvements to workspace creation, view rotation speed with selections\highlights, and Assembly tab switching.
To be honest I don't work in large assemblies much but I am curious at if there are some hard number metrics out there measuring when to get a Quadro card.
LearnOnshape facebook group
@PDY Simply having the latest driver is almost always a good idea. If webGL is not supported, you'll know -- the browser will display an error message instead of our UI.
Wizard status if you guys can automagically detect I have an optimus setup and that I'm using the slow card (I might want to do this on purpose occasionally so don't 'fix' it for me, just warn me.)
@traveler Yes, we should add the info at least for Windows -- the nvidia control panel. I'll talk to the right people.
For Linux, things are more complicated with Optimus: on my machine, I had to install Bumblebee and then invoke Chrome with --disable-gpu-sandbox, and even then I only got good performance with the latest Mint. Linux systems vary enough that I wouldn't feel comfortable providing official instructions; certainly not something as gross as what I had to do.
Perhaps a similar test for "Unmasked Renderer" could go in the help menu (or the appropriate sub-part. Help->About... perhaps).
