Chrome GUI selection problem
gal_razgal_raz Member, Mentor Posts: 39 ✭✭
When using Chrome at my win 7 PC I can't make selections.  You can see at the linked picture that the indicator select at offset from where it need to. https://goo.gl/photos/gWnDLzzWvcLpZaXTA
Firefox is working fine .
Gal Raz
  • NeilCooke3DNeilCooke3D OS Professional Posts: 1
    Is your Chrome browser up to date?  Check under settings > about from the top right menu.  Should say Version 43.0.2357.132 m - if not try updating.
    edited July 2015
    @gal_raz , It seems like graphics issue and also there will be chance of performance issue. Can you share your document or link to Onshape. They will definitely provide you some solution.
  • gal_razgal_raz Member, Mentor Posts: 39 ✭✭
    The same document at the same PC and at the same time run perfect on Firefox and IE
    Gal Raz
  • jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 668 image
    Is this just happening in this document/part studio, or is it a global issue for you?  If you would be willing, can you take a screenshot of your entire Onshape window and post it?  I have seen similar behavior before in testing where some element of the UI unexpectedly wrapped pushing everything down (which looks to be the thickness of the nav/tool bar) but I haven't seen that in almost a year.
    Jake Ramsley
    I found the problem. Chrome Zoomy extension. I delete it and it solve the problem  :)
    Gal Raz
