Creating offset shaped extrusions
If I am not clear in the title take a look at the two pictures of this Sunvisor plate in which holds your sun
visors at the left and right corners with two screws. I want to replicate these and need to know how sketch the center cylindrical piece that leans to one side. this is where the ball end goes into and the rod continues on through the angled hole at the tip.
Hope this helps,
Ethan
Still cannot hollow out the center protrusion and still have a hole straight into the larger cavity. Well the cavity needed.
Here is link to above doc Step through the features to see how I did it.
Besides the two issues above, I suggest you spend time cleaning up your model as it will make it easier to get things right and trouble shoot. A few suggestions:
1) Sketches should be fully defined,
2) Name at least some of the features.
3) You have redundant or unneeded sketches.
4) When you are designing from reference pictures, it is best to put them in correct position and then you can make a new sketch directly over them.
5) Not sure of your intent - do you want 3 parts? Otherwise you could Boolean the 'bushings' to main part OR better yet, they the counter-bored holes should just be done with your first sketch and extrude, No need to make separate parts.
Your original design created the three parts. I gave you options in point 5 on how to do that. Are you on track otherwise?
