how to remove construction lines
I've just made a chess piece, the way I did it was by making half of it then revolve it afterward. but when I revolved it there were many construction lines in there due to the points I had. Is there any way to remove them?
This is the link
This is the link
Prachi Member, OS Professional Posts: 262 ✭✭✭
Use view cube on right side of screen and change to shaded without edges.1
If they are being used - you probably just want to hide your sketch after doing the revolve. Hover over the sketch name in the feature tree and you should see a little "eye" icon. Click that icon to hide the sketch. You can show the sketch again at any time by clicking the icon again.
Also, maybe you want to the drop-down menu under the view cube - select "shaded without edges". Does that do what you want?
https://cad.onshape.com/documents/64288d4112101eca6779ece0/w/c7289ad777621c9a499cf474/e/2c48227b4190055fc80965db
see instructions here please
https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first#latest
