Building a basic Custom Properties Custom Table....problems...
john_allen289
Member Posts: 41 PRO
Hi,
I'm trying to build the most basic Custom Table to show a custom propery of a selected part within the Part Studio. I've butchered the Part Masses sample Custom Table to get this far
Started small, just 1 column 1 row to pull in one custom property, but my precondition to be able to select a part for the custom table is not working, error showing not compatible with Table, but I can see in the FSDocs an optional query of entities for Tables is there, but really not sure how to utilize this outside a precondition? Any thoughts. Thanks all.
NeilCooke
Moderator, Onshape Employees Posts: 5,988
The precondition for a table is to set parameter defaults (for example) in the table - it does not work with queries. You could cycle through all the parts in the Part Studio and create a separate table for each, but if there are a lot of parts your tables could get very long.Senior Director, Technical Services, EMEA0
Also, can you help explain how to apply the optional 'entities is Query' TYPE, and what this does? I couldn't find a custom table sample that used this as a reference case, didn't know if this might help extract specific Part data?
Thanks for your time as always.
