Using the custompropertyID to show custom property in a custom table
john_allen289
Member Posts: 41 PRO
Can someone show me the correct syntax to use the customPropertyID with PropertyType.CUSTOM?
I just can't get it to work for some reason (mostly because I have almost no idea what I'm doing with FS!), but trying hard to learn.....
var custom1 = getProperty(context, { "entity" : part, "propertyType" : PropertyType.CUSTOM, "custompropertyID" : 5f15b2e90eb1e3150e07046f } );
NeilCooke
Moderator, Onshape Employees Posts: 5,922
The ID is a text string so put it in quotes.Senior Director, Technical Services, EMEA0 -
Alex_Kempen
Member Posts: 255 EDU
It looks like one issue you may have been having is that you've misspelled customPropertyId. Keys are string arguments, so enclosing them in quotation marks is fine (unless you want to use a variable defined elsewhere as a key). Thus, your line of code should actually look something like the following:var custom1 = getProperty(context, { "entity" : part, "propertyType" : PropertyType.CUSTOM, "customPropertyId" : "5f15b2e90eb1e3150e07046f" });Software Developer at Epic Systems
FRC Design Mentor - Team 1306 BadgerBots0
var custom1 = getProperty(context, { "entity" : part, "propertyType" : PropertyType.CUSTOM, "customPropertyId" : "5f15b2e90eb1e3150e07046f" });FRC Design Mentor - Team 1306 BadgerBots
