Best Fit Surface on a Point Cloud
What is the best way to create a surface using points created in multiple sketches? I am working on a boat hull. The shape is defined by a table of Offsets. These are points measure up from a base, and over from a center plane. Back in the BC days(Before Computers), these points were taken from a scale model created for the desired hull shape. Obviously the resolution in these tables are thus fairly corse. I'm translating a Table of Offsets from1936. Their units are feet- inches-eights. And a "+" or "-" sign to represent a smidgen in one direction or another. So I have 100+ points that now need best fit curvature applied to them. I have attempted to create vertical splines contained by 3d splines and use the FILLED SURFACE feature. When I attempt to use the intermediate vertical splines as guides, it doesn't cooperate. Ideas? Suggestions?
  • robert_schartowrobert_schartow Member Posts: 8
  • MichaelPascoeMichaelPascoe Member Posts: 2,687 PRO
    edited March 2021
    Instead of using 3D splines, try creating 2D splines and manually fit them to your vertical rib measurements.
    When creating a 2D spline, it is tempting to use all of the data points. Try to use as few spline points as possible to get a smooth spline.
    For more detailed help, you can make your document public and post the link here.
    Can't make it public due to copyright restrictions on the data points. But I have created 2d splines on each of the sketch planes to connect the best data point sets. Then created a 3D spline across the top which creates the planksheer. I can create a surface between each section of vertical splines but cannot set the edges to match curvature, so there is not a smooth transition between each. And for some reason I cannot make a larger surface and use the vertical splines a guides. Not sure why. I was able to do it in the past.
    edited April 2021
    Lofting is very tedious. Every guide has to be perfectly placed. If you are still having trouble with this later, send me a pm and I will sign an nda for you. You could then temporarily add me to the document in order to trouble shoot.
  • EvanReeseEvanReese Member, Mentor Posts: 2,695 PRO
    Now that's some above-and-beyond forum help, haha.
