HOW CAN I MAKE A SHEET METAL FLAT PATTERN FOR A TRUNCATED CONE, TO MAKE A HOPPER?
I'm hoping onshape will automatically convert your words "how can I make" to "we should be able to make" so that this gets properly absorbed as an improvement request. I was surprised that sheet metal cones are not possible out of the box. Ended up getting curious and found some stuff that lets it happen but is an indirect sort of way. I imagine it would still function well when sent to be MFG. Check this document where I have tested it out and left a little screen recording of how I implemented the custom feature and cleaned up the resultant geometry. sheet metal cone example | Part Studio 1 (onshape.com)
https://cad.onshape.com/documents/428f8d67e3a953971323c83c/w/a1acb9decd86ac743f0a7ca2/e/4738c1fe5c15eb0e7d1bb28e
https://cad.onshape.com/documents/b61553ca7c0d34c686ac170f/w/29eed6f7cd27da738910e958/e/2551a6836ebdb7081c42cbaf
Twitter: @BryanLAGdesign
