Aus Beams FS become very slow
I have been using the FS, Australian Beams 2.0 (MBartlett)
Recently the script has become very slow, around 10 seconds per operation.
The FS file is tagged Deprecated.... is it an old version or abandoned?
Any thoughts? thanks
If all else fails, updating to the latest version (which appears to be 3.0) may result in better performance and additional features, both of which are probably beneficial.
When you mentioned a 3.0 version I had to find it.
Took a while to discover the script and finally yes it is much quicker on that version.
Thanks for your comment
Anyone else coming along I have found the Aus beams 3.0 here https://cad.onshape.com/documents/1932527edac323470b3700c5/w/fc73148cab9c8da1ac419ef1/e/95da2845221fb384c15678e8
