Sheet Metal Question
How can I make this part without the tear relief on the upper edge? The slope needs to be continuous without the 'bend steps'
https://cad.onshape.com/documents/5715c0dfec46d32ea0600e4c/w/773db9e088a3b588ea211f71/e/da80532a920a88d1f620f412
john_mcclary
Member, Developers Posts: 4,005 PRO
I agree, eventually Onshape may add some smoothness options to the SM tool0
Onshape sheetmetal is very picky about the corners, it doesn't allow for smoothing the corners like SW does.
One work around I found is to model it up as a solid part, then use the thicken command in sheetmetal, it usually works a little better, but still isn't perfect
