Circular patterns won't close
henry_feldman
Member Posts: 135 EDU
OK I've been using OnShape for years and have no idea what is preventing me from circular patterning. So the scenario is as follows. I have a circle on a plane. I have a sketch with a circle (on an offset plane from the top plane). I have a line of circles on the vertical radius line from the origin. I want to make a circular pattern of those circles (make a strainer pattern if you will). Now the first thing that's weird is all my circular patterns are defaulting to 240 degrees (not 360). And it will not let me drag past 240 (I can type in larger). If I go to 360 the pattern disappears, while at 359 it works (but has overlaps).
Any ideas?
Any ideas?
Once you make a circular pattern open and confirm it, I don't think there's an easy way to make it closed again. At that point, it's probably easiest just to remake it.
You can also read more about this on the circular sketch pattern help page.
Circular Pattern FS
Are you able to share a link to your document? That does seem like strange behavior.
If all you want is a "strainer" pattern you might also try my Speaker Pattern feature. You can get this in one feature with zero sketches if you're going for something like this.
