How do I move a derived sketch?
I have a skeleton sketch that I am deriving into another part studio. It comes in at the origin on the target studio. I want to move it. I can't move it using the transform tool. In contrast, I can move a derived feature that is solid geometry using the transform tool. But this particular derive is 100% a sketch, and I can't select it within the transform tool to move it. Is there any workaround? Thanks.
EvanReese Member, Mentor Posts: 2,468 ✭✭✭✭✭
I'm probably too late to help with your project, but using the Super Derive feature from @ilya_baran should work. It lets you pick a mate connector to orient to (among many other awesome things). Here's my example.
1
I tried this just now, and could not move the "use edge" sketch made from the derived sketch. I actually could not select any of the new sketch in the transform selection tool. So I took it a step further, and made a new sketch from scratch, not linked to any derived sketch, and simply tried a transform on that sketch. The same thing happened, I could not select the sketch once inside the transform tool.
Hi Evan, this is really good. Thank you for sharing. I tried it out and its much better than the built in Derive. I can add planes, sketches, etc, to the SuperDerive feature, and locate them all wherever I please in the target part studio. The only functionality I see missing is the ability to select a mate connector on the source geometry for location. The way I'm seeing it now, is it mates only the origin of the source geometry to any selected mate connector on the target part studio.
I think so. Since code is public, feel free to give it a shot. The key ingredient is the mateConnector option in addInstance, as described here https://cad.onshape.com/FsDoc/library.html#module-instantiator.fs -- that'd be the query for the special attribute.
