Tangent with distance offset
Patxi_LZPatxi_LZ Member Posts: 9 EDU
Hello,
Is there a way to add easily a distance offset to tangent constrains in assemblies ?
For the moment I make a sketch, I project the contour of the surface, I add an offset, I insert the sketch in my assemble and I use tangent.
    You are doing it right - you could also just offset the surface and use that.
  • tecnicoBMETtecnicoBMET Member Posts: 1 PRO
    Yes, I have the same issue. This is a limit of usage...
