Hole callout precision
T_RathierT_Rathier Member Posts: 47 EDU
When using the hole callout tool there is no option for controlling the precision of the hole diameter or the depth, it just takes on the overall drawing precision. Is there a way to do this?
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 578 image
    @T_Rathier There is not a way to control precision and tolerance of hole callout parameters yet.  If you notice, there is a hole table in part studios where these would also need to show - so this is not a drawings only need.  I create a ticket for your request and tie you to that improvement.
    @jonaskuehling I created a ticket for you and tied you to the improvement.
  • jonaskuehlingjonaskuehling OS Professional, csevp Posts: 17 PRO
    @PeteYodis May I ask you to be tied to that improvement request as well? Just ran into the same need, where a full drawing for a rough steel profile weldment with rather coarse dimensions (whole millimeters only) would need a few hole callouts for threads and wasn't able to show the core hole diameter with higher precision like one decimal place (e.g. 8.5 mm bore for M10 thread).
    Thanks!
