Linear pattern, snap angle
CaptainBisquickCaptainBisquick OS Professional Posts: 33 ✭✭
edited July 2016 in Community Support
The linear pattern tool doesn't accept angle input?
    You drag the direction arrow away from orthogonal, and an angle input box pops up
  • Narayan_KNarayan_K Member Posts: 379 ✭✭✭
    @CaptainBisquick,you can give the angle as below,
    1. Drag the square box shown in pattern tool.
    2. Give the required angle from reference entity.
    1.PNG 29.4K
    2.PNG 24.3K
    By dragging the direction arrow at the highlighted points as below will move the construction lines at any angle.
    You can later provide angle for this construction line which will be an angle input for linear pattern.
    OOoops, my bad, I misremembered (angle input box does NOT pop up). I tried to verify at the time, but the computer I was on does not play nicely with Onshape CAD, and I forgot to revisit.
