How do you emboss on an unevenly curved surface?
I have been informed that the Onshape wrap feature only works with uniform cylinders. I need to make a emboss on a curved(not cylinder) surface. There are 4 circles that I want to emboss onto the part. Help would be appreciated!
Here is the link to the project.
https://cad.onshape.com/documents/81d2f7f0aa4bb8b799982f93/w/640d51f8ef753957f1a2f4c5/e/2d056ec58a69df83ead1cf71
MichaelPascoe Member Posts: 2,401 PRO
Ah, for that shape, this method will work:- Create the ellipse shape on the top plane
- Create the hexagon pattern sketch on the front plane (Note: I used the custom feature Measure Value to get the parameter of the ellipse and calculate the spacing of the hexagons.)
- Use the custom feature Fold by @konstantin_shiriazdanov
- Fill the hexagon curves
- Thicken add/remove the hexagon surfaces
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴2
Here is what I want for more clarity.
except without the perfectly round sphere and compatible with more organic shapes.
Example studio
here is the link to the project
https://cad.onshape.com/documents/81d2f7f0aa4bb8b799982f93/w/640d51f8ef753957f1a2f4c5/e/20e4e24f25978f355dea3ff8
https://cad.onshape.com/documents/bad89fe0c2b39b8311c17fa8/w/8bec194c72a504899997ae8f/e/4d1406d7f109c4edd6cf99efLearn more about the Gospel of Christ ( Here )
How does one use a vector file to import something like a logo into a 3D model to emboss? I created the logo in Illustrator and can save out as a dwg or dwf.
You could then use the Extrude feature or Wrap feature to add or remove it from a solid part. Another approach would be to use Split, then Thicken.
