How do you emboss on an unevenly curved surface?
vikram_koli595vikram_koli595 Member Posts: 31 EDU
edited May 2021 in Community Support
I have been informed that the Onshape wrap feature only works with uniform cylinders. I need to make a emboss on a curved(not cylinder) surface. There are 4 circles that I want to emboss onto the part. Help would be appreciated!
Here is the link to the project.
https://cad.onshape.com/documents/81d2f7f0aa4bb8b799982f93/w/640d51f8ef753957f1a2f4c5/e/2d056ec58a69df83ead1cf71
    @vikram_koli595 try using a sketch to SPLIT the face and then apply the MOVE FACE tool.  Does that meet your intent?
  • vikram_koli595vikram_koli595 Member Posts: 31 EDU
    Sorry This is what I understand. I Split the main part with the circles then I move the separated pieces?
    Here is what I want for more clarity.
    Tutorial How to engrave a word on a complex surface  3D CAD Model  Library  GrabCAD
    except without the perfectly round sphere and compatible with more organic shapes.
    @vikram_koli595, see here is an example of the approach that I described.
    Hope that helps.
  • MichaelPascoeMichaelPascoe Member Posts: 2,803 PRO
    edited May 2021
    One way to do this is with a custom feature called Surface Text by @jan_vykydal
    Example studio
    RENDERCAD
    Thanks for the methods @matthew_stacy and @MichaelPascoe. I tried these methods on a curved shape and it worked great, but as soon as I tried it with an elliptical cylinder, my hexagon tessellation started looking distorted after I split the sketch from the actual model and after as I moved the faces. I created another part studio where I show these distortions.
    here is the link to the project
    https://cad.onshape.com/documents/81d2f7f0aa4bb8b799982f93/w/640d51f8ef753957f1a2f4c5/e/20e4e24f25978f355dea3ff8
    Make your document PUBLIC so it can be copied.
    edited May 2021 Answer ✓
    Ah, for that shape, this method will work:
    • Create the ellipse shape on the top plane
    • Create the hexagon pattern sketch on the front plane (Note: I used the custom feature Measure Value to get the parameter of the ellipse and calculate the spacing of the hexagons.)
    • Use the custom feature Fold by @konstantin_shiriazdanov
    • Fill the hexagon curves
    • Thicken add/remove the hexagon surfaces
    https://cad.onshape.com/documents/bad89fe0c2b39b8311c17fa8/w/8bec194c72a504899997ae8f/e/4d1406d7f109c4edd6cf99ef
    RENDERCAD
    Thanks @matthew_stacy and @MichaelPascoe For the help. Sorry I didn't make the document public @matthew_stacy. I will keep that in mind next time. Thanks again!
  • VMVM Member Posts: 15 PRO
    Hello,
    How does one use a vector file to import something like a logo into a 3D model to emboss? I created the logo in Illustrator and can save out as a dwg or dwf.
    edited October 2022
    @VM While inside a part studio, within a sketch, there is a button called "Import DXF or DWG". If the files are not already imported into your document, you can do that from within the "Import DXF or DWG" dialogue.
    You could then use the Extrude feature or Wrap feature to add or remove it from a solid part. Another approach would be to use Split, then Thicken.
    RENDERCAD
