Transforming a movement into a sketch
frank_ring
Member Posts: 39 ✭✭
Hello,
the following task should be solved.
The pin, which describes an ellipse due to the deviation, should be cut out in the plate as slotted hole.
How can I draw the path of the pin in order to cut out the exact slot later in the workshop?
https://www.dropbox.com/s/i265rnolmhvxarw/Pinhole%20Animation_3.mp4?dl=0
https://cad.onshape.com/documents/46f3fdcb6d880251505cbe99/w/6ff4a3cf5cbefc7b50113ee5/e/2d9f673abaa409f9052313ce
Thanks for your help!
Optionskonstantin_shiriazdanov Member Posts: 1,221 ✭✭✭✭✭
Please ignore the pinslot guide near the saw blade, I designed this only for the animation.
The current cutout was connected via 3 points with a curve and is, as it can be seen, not correct.
https://cad.onshape.com/documents/3a5d6c56d90bba5f6c00f7e2/w/38cc2a5cccfeb0e8b431e193/e/6cbd064f1213bb1b27fa7612
