Can I draw a line in the sketch during in-context part creation to a point in the ghosted assembly?
RChilcoat
Member Posts: 12 ✭
Finally getting into in-context editing. Works well as long as what I'm sketching includes points within the purple sketch plane graphic, but if I want to draw a line from the sketch plane to somewhere else that is co-planer with the sketch plane but is in the ghosted part, I can't. Can I refer to points (for example corners of parts) that are in the ghosted assembly? Thanks. Still learning.
tim_hess427
Member Posts: 648 ✭✭✭✭
Here's the help page for the "use" tool. Use (onshape.com)
If you need to, you can always restore a document to a past point in time, as well: Document Management (onshape.com)1
