Please Help With Transform Sketch / Redimension
monique_vomonique_vo Member Posts: 2 EDU
edited May 2021 in Community Support
I am making a chess set on OnShape and accidentally made the piece too small. Is there a way that I can re-dimension it without having to make the piece again?
  • PrachiPrachi Member, OS Professional Posts: 262 ✭✭✭
    scale during transform
    @monique_vo - You should be able to open up your sketches and features and just edit the dimensions directly. Is there a reason that isn't working for you?
