Generating a sketch that can be derived in other part studios
Cedric_Eveleigh
Member, OS Professional, csevp Posts: 73 PRO
I'm new to feature script. I'm trying to create a feature script that generates a sketch that can be derived in another part studio. So far, the feature script generates a sketch, but this sketch is not shown as an option when attempting to derive it in another part studio.
Standard sketches can be derived, so I looked into the standard sketch feature (sketch.fs in the std code), and I tried copying some stuff, but I couldn't get something working. I don't understand what's going in sketch.fs (with the startFeature, endFeature, return newSketchOnPlane, etc).
Any help is appreciated.
Still, it's quite annoying to have to put an empty sketch in every part studio and remember to select the entire part studio when deriving.
I need to derive a specific sketch (hopefully generated by a feature studio) from a part studio with a lot of content, so it's not an option to derive the whole part studio. Your suggestion is interesting but it doesn't solve my problem.
The only way I know of to achieve what you're trying to do is with the API.
The API can be used to create "real" sketches programmatically.
I've also been able to take a sketch from one part studio and recreate it in another using the API, but I'm not sure if that can be done with a sketch created via FS. It might be possible I just haven't tried it yet.
