How do you delete a line?
landyn_rhoadeslandyn_rhoades Member Posts: 2
I drew a line and I want to delete it, but I don't know how to.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,926 image
    Edit the sketch, select the line, hit delete key.
  • jake_delano19jake_delano19 Member, csevp Posts: 19 EDU
    To delete a line in a sketch you can right-click on the line itself and select "Delete Sketch Entity" from the dropdown menu that appears,
    use the Trim tool,
    or click on the line and hit the "Delete" key on your keyboard
