How do I create a part from a surface?
peter_paton
Member Posts: 43 ✭✭
In the attached "bottom tray" I have sketched the completed item is showing as surfaces where I would normally see a part. Is there a way to convert, or have I done something fundamentally wrong somewhere? All other sketches/extrusions have ended up as parts which were able to be used in assemblies but not this one. TIA Peter
ISS NX418 Guards | Bottom Tray (onshape.com)
I realize this may not be what you are after, but I found a little time to create this part with a different workflow. Feel free to look through this and discard any ideas that are no help to you.
https://cad.onshape.com/documents/b293d18390dfb7468df8cf43/w/9d38c305a845ac6998d9d65d/e/d937bf0b3446332d4cd54762
