How to scale a series of splines?
Cobalt_EchoCobalt_Echo Member Posts: 31 ✭✭
edited June 2021 in Drawings
I have an image that I am tracing using spines, then I would like to resize the splines to make it larger.  Specifically, on this document, I am trying to scale the size of the bulldog head in order to make it larger.  Appreciate any suggestions or ideas.  I've tried dimensioning the entire thing, but it seems to only move that specific point.
https://cad.onshape.com/documents/50af1d3ca22269b6963ee320/w/99ed961ac2e4903a21a99af3/e/fdb4bdfe8196e19d31d1ca94
Edit: In retrospect, I don't think this is in the correct category for the forum, but it doesn't give me the option to move it.
  • MichaelPascoeMichaelPascoe Member Posts: 2,803 PRO
    Here is one way to scale a sketch:
    • Remove all dimensions from the sketch
    • Dimension one item in the sketch to the size you want, the sketch will automatically scale to that size.
    RENDERCAD
  • Cobalt_EchoCobalt_Echo Member Posts: 31 ✭✭
    edited June 2021 Answer ✓
    @MichaelPascoe, Thanks!  It was the dimension for the small offset I had by the ear that threw the whole thing off.  Appreciate your time!
    RENDERCAD
    edited June 2021
    Anytime!
    RENDERCAD
