Tab bar thumbnails
Some time ago, when I hover over a newly created part studio on the tab bar, I can't see a thumbnail. Also, when I make some changes on an older design, the thumbnail remains the same.
Paul_J_Premakumar Member, Onshape Employees Posts: 235
The thumbnail generation can occasionally take longer to generate. If you try after some time (say 30 min ) does it appear?0 -
stavros_panelis Member Posts: 2 ✭✭
Thank you very much for your prompt reply. It seems that it works perfectly after some time!!!
