Extrude and offset
hello,
in solidwork is possible, when you do an extrude, place an offset, like in the picture.
the same feature in onshape is possible?
thanks
thanks
As an alternative, you can use this custom feature I wrote called Offset Extrude:
https://cad.onshape.com/documents/114db515c4c0555c858c84a3/w/d1dcd2c1c42702c1f49b1f02/e/073daba46b54994cb29b6b16
How to add a custom feature to your toolbar:
yes, i use Move feature or i create directly an Offset plane at the right distance.
i tried your custom feature but it doesn't work how i want
John_P_Desilets
second end position works in a different way
the feature that i'm searching it would work in this way: starting from a sketch on a plane, the feature can create an extrusion on another plane but without to put an offset plane. (like in the picture. i have a sketch on a top plane but the extrusion is on plane1
