Linear Pattern of Feature? Select the Feature from the Feature list. (eg Extrude 1)
 christopher_owens
                    Member Posts: 235 ✭✭
christopher_owens
                    Hello! I did figure out how to do this "easily" in OS! I wanted to make a copy of the cutout in the steel tube and place it near the other end. I was playing with Copy Sketch (ugh) and creating a part to move and use to create the cut out. But finally ended up trying Linear Pattern. Of course you can't just select the feature from the Feature list. Had to use Face Pattern, and after a few "what ifs" I found I could "Create Selection" and use "Pocket". Intuitive?? Also under Face Pattern there is no XYZ. (Old habit of not liking to select feature entities as they might change or go away. Big fan of Axis created at the intersection of two Planes {Pro/E habit}) Be nice to just select the Feature (eg Extrude 1) and then Linear Pattern. That way ALL the surfaces of the feature are selected at once!
Now in Onshape we can create a new part by solid extrude instead of creating cut,then pattern that part using linear pattern.
By Boolean operation we can get desired cut.This may require one step more but we can avoid the face selection.
