Can my configured assembly be set to be a "Master" assembly?
jmccormick
Member Posts: 40 ✭
I have spent days setting up a configurable assembly that works great. BOMs update, Properties change accordingly, the works...
Here is my problem - when I use the assembly to review or discuss the product with someone, I am hiding and suppressing parts all over the place. The next time I go to the configured assembly, the parts are not viewable. My Configuration table changes when I suppress something and will not unhide the parts I have hidden. Of course, Onshape has conveniently saved everything so I have no way to exit without saving. 😁
Can I somehow lock the configuration table so it does not permanently change? Can the configuration be the Master assembly no matter what was changed outside of the configurator?
lana
Onshape Employees Posts: 757
@jmccormick
See if you can use a version or a recent state in document history for demo. You should be able to hide parts and change configurations while viewing a version, none of those changes will be saved.
Still, it would seem that once the configuration table is set, it should not be editable outside of the configuration UI. When I select a configuration, I want THAT configuration to be displayed the way it was originally configured.
(When are you going to make more YouTube videos? I really like your explanations.
I think this will actually be helpful for me. Sometimes in complex assemblies it can be difficult to scan through complex configuration tables and make sure I'm setting things correctly, so it may be helpful to just open up the configuration I want to change and make the changes in the model space.
Glad you're watching the videos. I've got a big list of ideas, but not the time to do 'em lately. Hopefully soon.
