Change apperance of a bend line in flat part
andy_nias
Member Posts: 7 EDU
I am wondering if there is a way to change the appearance of a fold/bent line in a flat metal part. In the UK, british standards use a double dashed line to denote a fold line. Onshape seems to use a centre line which is really confusing my metalwork students. I was wondering if there is either a way to change the appearance or another way of getting a line into the drawing. Thanks
pmd
Member, Developers Posts: 64 PRO
@andy_nias If you mean in a drawing of a sheet metal flat view then Drawing Properties/Views/Flat Pattern rules lets you set the line type and colour indivudually for up and down bends however the choice is only from Solid, Dashed or Center.0
@andy_nias refer this link for the exact solution: https://forum.onshape.com/discussion/21721/changing-line-color-of-exported-dxf
