Part Studio to CNC mill?
scott_caskeyscott_caskey Member Posts: 53 PRO
I am nearly complete with converting my Milling machine to CNC.
Can someone point me to a tutorial or provide suggestions on how to go from a part studio in OnShape to the file needed for the CNC machine software (using Centroid Acorn with CNC 12 software) ?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,002 PRO
    It looks like it accepts step files. So right click your part in the part studio and select export. Then choose .step as the format. Then import the step file inwo cnc12
  • scott_caskeyscott_caskey Member Posts: 53 PRO
    So you don't need another application to define the tools types/sizes and sequence of cuts, depth and number of cuts, speed, etc., ?   Is all that done in the CNC application on the mill?
    Thanks for the input John.
    I'm not familiar with CNC12 or contriod.
    but typically CAM software is required to define tools/cut paths/feeds/speeds etc. and convert it into G code specifically for each brand or type of CNC
    the fact that software can open a STEP file and is part of centroids suite, tells me it is likely the only CAM software you will need to get going.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,035 PRO
    You need a CAM application. Onshape is for the design. Then you export it as as STEP to the CAM software. In the CAM software you will generate all the toolpaths. The CAM software will then generate G-Code, which is a text file. This is the file you will send to your CNC Controller. The CNC controller in your case is Centroid.
    Onshape does not currently have a built in CAM function. If you are doing hobby work, Fusion360 has a free cam function. If commercial use, their license is about $500 per year. Or you can go to MasterCAM which is much more expensive. There is a free 3rd party software for Onshape called Kiri:Moto in the Onshape app store. I have not used it yet to comment. Fusion360 I used a fair bit (for hobby only). Its good for CAM (but I can't stand it for modelling, ha ha).
  • michael3424michael3424 Member Posts: 751 ✭✭✭✭
    Onshape also has at least some support for other CAM programs.  I use SprutCAM, which is pretty inexpensive so far as CAM programs go and has versions to support 3D, 4th/5th axis, plasma cutters, robots, and a bunch of other machine types.  It is developed in Russia and can be a bit daunting at first but there are some good YouTube videos, by SprutCAM themselves, SprutCAMUK, and SprutCAMAmerica that help you get started.  The latter is the USA distributor for the product.
    Ok.  Thanks everyone for the input.  I believe the CNC12 application handles everything after the import of the STEP file.  I was unsure of where that took place.  I do 3D printing and that requires a separate slicer application usually so I figured I would need the CNC Mill equivalent.    Thanks!
