Part Studio to CNC mill?
scott_caskey
Member Posts: 53 PRO
I am nearly complete with converting my Milling machine to CNC.
Can someone point me to a tutorial or provide suggestions on how to go from a part studio in OnShape to the file needed for the CNC machine software (using Centroid Acorn with CNC 12 software) ?
-1
Thanks for the input John.
but typically CAM software is required to define tools/cut paths/feeds/speeds etc. and convert it into G code specifically for each brand or type of CNC
the fact that software can open a STEP file and is part of centroids suite, tells me it is likely the only CAM software you will need to get going.
