Possible MASS_OVERIDE Bug?
EFishEFish Member Posts: 16 EDU
I'm currently finishing up a bearing generator with a list of bearings preset from VEXpro. But also can generate its own bearings. I'm trying to apply a mass to the preset bearings, but it returns an error when a numerical value with a unit of weight is applied.
Precondition of setProperty failed (definition.value is string)
     54:9       onshape/std/properties.fs (setProperty)
     227:13   In-Place Bearings (const myFeature)
     55:17     onshape/std/feature.fs (defineFeature)
     Bearing Testing (In-Place Bearings)
     Bearing Testing
When given a string value, the properties tab errors out. So I'm curious if this is a legit bug in the system, or if I'm doing something wrong, and if there is a workaround. Thanks in advance!
Here is the document link: https://cad.onshape.com/documents/028ca8fb10baf53e1f6fce96/w/b1250a450d0ba88f0a8b1811/e/aea21598d349c81bcdcee291
FRC Team 2471 Designer - Alumni
Seattle Pacific University - Mechanical Engineering
efishg2020@gmail.com
  • Alex_KempenAlex_Kempen Member Posts: 258 EDU
    edited June 2021
    Okay, the precondition for setProperty is definitely missing an else if (definition.property == PropertyType.MASS_PROPERTY_OVERRIDE), especially since the documentation clearly says "a value with mass units if it is `MASS_OVERRIDE`". @lougallo, can you tag this as a bug?
    For now, a workaround is probably to play games with your material density. You might also be able to type @setProperties(context, definition) to call setProperties directly, bypassing the precondition.
    As a side note, I find your FeatureScript interesting, but I do want to note that instantiating multiple bearings in a part studio is probably not great since they won't work properly with the BOM (Kinda an Onshape internal limitation), and they'll hurt performance across the board (This is also why my Belt FeatureScript no longer offers COTs pulleys as an option, although it definitely did make me sad to disable them). You can, however, mitigate some of this by offering an option to exclude your bearings from the BOM entirely.
  • EFishEFish Member Posts: 16 EDU
    Yes, I am aware of the BOM issues, I will definitely add the option to exclude from the BOM, thank you for the suggestion. The main idea of this script is to make it easier to insert bearings so that rather than having to derive from mkCAD or from and import, it will be able to generate in place. Which I think is more efficient anyway, as well as it would make it easier to generate any bearings that are not available on VEXpro.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    I have pulled a bug for you two.
