How can I flip the normal on a surface?
Tom_Schoenhofer
Member Posts: 5 ✭
in General
Creating a surface using LOFT there is no option for which side is the outside. I think it assumes the top surface is always convex? This has never been a problem before but now when exporting a surface for VR or sending to someone else the image or surface object appears backside out.
Thanks
Thanks
Tom_Schoenhofer
Member Posts: 5 ✭
OK I found the answer. I was half way there.
Loft the surface, it has the normal backwards.
Then offset the surface a very small amount, I used .1mm .
Then use DeleteFace on the outside (original surface) and check leave open.
This leaves the flipped normal surface on the inside.
All good now for export.
If there is no way to flip the normal it's no big deal, I just thought Id ask because I couldn't find a solution.
I figured a workaround- I select the surface and create a part with thicken that is 1mm thick. So I now have two close surfaces = normals pointing both ways and at least the correct surface is visible now.
I also tried offset surface where you can copy and/or offset a surface in either direction but this does not change its surface normal.
