How to draw a screw thread?
If you need a cosmetic thread that looks good in the model but do not need the 3D aspect, you can use the cosmetic thread custom feature found here:
https://cad.onshape.com/documents/60de6d7733c1f01904ca5910/v/5d4bf4f5092053503ba95894/e/e4819e5cbfc03801eeb168e9
If you need a 3D thread, you can use the Thread Creator custom feature found here:
https://cad.onshape.com/documents/6b640a407d78066bd5e41c7a/v/845d049782179b9faee8b6e6/e/c953720c264ce001f1a82dc1
To add custom features to your toolbar, click the + Custom features button and click on the custom feature so that it turns blue. Do not copy the document.
Hope this helps!
tl;dr
Create a helix and create your profile sketch normal to the start of the helix. Make sure your profile sketch 'pierces' the helix, then sweep!
