Beam featurescript butting arrows not available in all size profiles
Simon_KozinSimon_Kozin Member, csevp Posts: 8 PRO
I tried support but was directed to the forum. In the BEAM featurescript there is a nice feature that brings up arrows to allow you to change the orientation of the tubing butt joint. Unfortunately this doesn't seem to work in all shapes/sizes of tubing. I first noticed this in the 2x2x1/8 ANSI square tube (It works in the next size up). It also seems to be the case in other sizes. Is there a chance of getting somebody to look at that? Is it somehow related to the size of the beam features?
Thanks!
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,432
    edited June 2021
    I’ll have a look - I see coping is broken on that size too.
    Fixed - thanks for reporting.
    Also added ability to select curves (that are lines or arcs) for profile to follow.
